- Feb 23, 2006
- 9
- 0
- 0
When I start itunes I can get the home page of the music store to pop up but after I click a link it just gets stuck in "accessing" with the striped bar instead of the full one. I have turned off my firewall, I have left on the firewall with the itunes exception I tried deleting the file in the sc folder, I have installed an earlier version of itunes(6.0).
Also when I exit itunes it stays in memory and uses up 99% of the cpu according to the task manger.
Another thing this is a new rig I just built on my old computer it ran just fine, I never had any problems with it. Any suggestions?
I am running winxp sp2(fully updated)
amd 3200 vience
2gb of gskill ram
7900gt
asus A8N5X
After typing that only thing I can think of is the onboard sound causing a prob somehow? Also I can play quicktime movies with no problem.
Thanks
amd 3200 vience
2gb of gskill ram
7900gt
asus A8N5X
Thanks
