Problem with installing PCMCIA NIC - programmable IRQ interrupt not activated. - FIXED!
cirrus1
I have just installed a D-Link DFE-680TX Cardbus Network card in my laptop. The laptop recognizes the card at bootup
and installs the drivers ok. After reboot I go into device manager and sees the card listed as problem device. On
status it says something like
"THis device doesn't work because Windows-support for programmable PCI interrupt haven't been activated"
"To activate this support click on Activate IRQ-steering"
I click the button and go rebooting. But Windows doesn't change anything.
I have checked the ressource tab and there it says that the card conflicts with the programmable interruptcontroller & Motherboard-ressources.
I guess this is caused by the laptop which is an older IBM 760XL from 97' or so, which probably can't support ACPI.
Any suggestions is very much appreciated, as I feel that I have tried all like swapping PC-Card slots disabling com
ports etc.
Thx for your reply, but I've actually got it working 😎
There was an option in the IBM Configuration Utility to enable Cardbus - then it worked 🙂
Thanks anyway
