Problem with IEEE1394
lupin
2,944
I posted the same question on General Hardware two weeks ago, but didn't get any replies. Here is another try.
I purchased a unit of Tekram TR-1394W firewire adapter. I installed it, and windows XP
detected the card and installed an appropriate driver with no problems.
However, when I try plugging devices into it, they simply are not detected.
I'm trying to connect a Nikon D1x digital camera and Epson Stylus Photo 2200
printer, both uses Firewire connections.
I'm using an Asus P3B-F (Intel 440BX) motherboard, Pentium 3 733Mhz,
and Windows XP professional.
Anybody ever have similar problems or any idea what's wrong??
I tried tekram's website for an updated driver or some sort, but found nothing.
agnitrate
3,761
Double post? It's a septuple post!
Anyways, is this one of the expansion cards you can plug into a mobo header or is this like a PCI firewire card?
If it's the expansnion, I would probably think that the expansion piece is what is at fault. If it's the PCI, I don't think that would really be the issue. You could try moving it to a different PCI slot or maybe go to their website and get new drivers for it.
Good luck!
-silver
PowerMacG5
7,701
Good luck!
-silver
Damn, beat me by one minute.
lupin
2,944
it's actually a PCI, and yes I did try moving the card around-- no effect.
and tekram's website don't really have any drivers for the card.
any other suggestions?
Storm
3,952
Return the card and try another firewire card from a different manufacturer... Adaptec has their DuoConnect cards that have firewire and usb2.0. If you get the same problem its on your side and not theirs.
