problem with ide controllers
ramike64
I have a DFi AK 75-ec mobo with 768 mb ram, 900 mhz amd thunderbird processor, 40 gig Maxtor EIDE hdd running win 98 se. I formatted c:/s and when I was finished there were yellow exclamation marks next to my primary and secondary ide controllers in device manager. Any suggestions? I tried to remove and then reboot but they just came back. I'm going to try a new ribbon cable.
Thanks,
Mike
Thanks,
Mike
Need to install chipset drivers for your motherboard. I'm going to try to find them for you.
thank You and have a great day. That should clear up the problem with windows seeing my dvd and cd/rw drives too correct?
I can't say if it will or not. But might be a step in the right direction.
What kind of issue are you having with them? Disappearing? Or just never there? Not there when you need it to be there?
Since I formatted my hdd they haven't showed up in My computer. The only way I can access them is by choosing cd rom support in windows setup.
I reformatted my hdd again and reinstalled everything and it's great. Thanks so much for your help.
