Problem with IC7 max3 and new NEC 3500a
MIDIman
3,594
I have an IC7 max3, second to most recent BIOS. Sata is disabled and configuration is like this:
IDE1 - master - Seagate 160gb - System
IDE2 - slave - Seagate 80gb
IDE3 - master - Sony DVD-RW 510a
IDE4 - slave - Seagate 160gb
I replaced the Sony burner with a brand new NEC 3500a. Computer boots past BIOS, but halts before the WinXP logo with "Insert System Disk etc" error.
I pulled the 160gb Seagate - computer boots. If I pull the NEC burner, the computer boots.
I tried putting the drives on cable select - nothing.
The IDE4 160gb used to be a system drive in another system (Windows system folders removed, but the drive was not formatted). It is listed as (Active) in the WinXP Disk Management.
I then place a similar 120gb Seagate on IDE3 - i.e. one that was a System disk, but is still in tact (so in this case, all four Seagates). I reformatted it (though, oddly, its still listed as (Active) in Disk Management - what does this mean?) in WinXP. I then removed the IDE4 Seagate 160gb and replaced it with the NEC. Sure enough, it boots.
So whats so special about that 160gb? A bit confused here...I'm doing a test burn now.
My plan right now is to move all the data from the 160gb to the fresh 120gb, and reformat the 160gb.
Any ideas welcome.
MIDIman
3,594
Odd - so I reformatted the 160gb, and still have the same problem on boot.
I switched the two - 160gb as master and the burner as slave, and the computer boots. Why can't the burner be master on ther second IDE channel?
mboy
3,309
Double check the jumper settings on your drive.
I would have to double check later, but I believe my 3500a is a slave on my 2ndary IDE controller.
