Originally posted by: ScottSwingleComputers
Originally posted by: PaulNEPats
I get a picture when I connect the Cable Out from the Wall Jack straight into the TV. But I can't get Cable TV this way. There's no Out to TV connection on the back of the Cable Box, so the 75 ohm connection on the back of the TV has no cable to connect to. I don't know how to fix this.
You dont really want to do it that way even if possible. You will lose ALL benifits of having an HDTV. In order to use HDTV correctly, you need to use the component or HDMI.
Are you getting absolutely NOTHING on your screen when turning on the cable box? Are you sure you have the tv inputs set to what it needs to be for a component or HDMI input? My guess is no, since you get a picture plugging coax directly in, and you aren't changing anything when trying to view your cable box. Even if your cable box isn't setup correctly with the cable company, you should still see SOMETHING come up on your screen.
