- Dec 1, 2000
- 1,235
- 0
- 0
**** This is a thread where the problem has changed. I've left the original stuff at the front because it is still relevent, but the main thrust of the problem is farther in the thread ****
I was forced to do a complete reinstall of XP Pro, and I can no longer get Windows XP Update to work. It downloaded a couple of "critical updates" but won't work on 14 critical updates and SP1. Scan for updates works, as well as the license agreement, and then when you try to start the download/install it begins to download and then says: "[BIGREDX] No updates were installed... (paraphrasing) try again..."
Strangely, I also can't download the deluxe portfolio manager from the MS moneycentral website that I used to use to manage my stocks. It also won't work and pops up a help menu instead (and I've tried everything there to no avail).
I was forced to download and install Netscape because an online service I need to use for work only works with Netscape. However, I've had NS and IE on at the same time in the past, and I didn't experience this problem.
Any ideas?
Any ideas?
