Problem with Hauppage WinTheater
macguyver
Hey all, I have a win theater tv card by hauppage, and when i put the card in, it confilcts with all of the irqs i have taken already, as if it won't assign itself one not taken (there are 3 free i believe). Then, I tried to disable soem of them, and set them to be reserved, etc, and now the entire machine won't boot if the card is in. Any ideas?
thanks
You could try taking all of your PCI cards out and then install the WinTV card first, install the software for it, and then install the next card. Tip: don't install any card that uses an IRQ in PCI slot 1 as it uses the same IRQ as the AGP slot. The other thing to check is your system BIOS. Make sure "PNP OS" is NOT enabled.
