Here's the issue: Yesterday I was using my computer (not installing anything new, just some web browsing). I go away for a couple of hours and find the computer shut down. I proceed to turn it back on and when the windows xp logo comes on and freezes. I then try rebooting in safe mode, it loads the drivers but then when it gets to d347bus.sys it says 'hit esc to cancel', if I don't hit esc it freezes, if I hit esc it goes into safe mode and loads up.
Here's the 2nd problem (definetly related). One of my hard disks (actually a partition of one disk) is saying that it is not formatted when I try to browse it. Wtf??
So I search for this file d347bus.sys and rename it to see what happens. I reboot and now windows is able to startup in regular mode but the one partition is still said to be 'unformatted'.
So I then figure it must be something wrong with the windows so I re-install a fresh copy of windows over the current copy (I didn't reformat the partition).
No luck, still same problem with the drive. I believe that the drive is ok because when I boot up in DOS mode I am able to view the contents!
I'm running Win XP Pro. Any help appreciated.
Derrick
Derrick
