Problem with Geforce MX after reboot of Win98
pwan
9
I have used my Geforce MX for about 7 months and everything works fine. However, yesterday after my computer reboot itself, I couldn't let my MX works properly again.
Most of the time it will 1)load into windows and hang up after a few seconds or 2) couldn't load into windows.
I've uninstall and reinstall the driver and the VIA drivers but nothing work.
I tried to format the hard drive and install everything from the beginning (got a copy of ghost file), the computer will freeze up during modify the system setting (the last part of the installing process).
My config is:
C400 with Aopen ax63 pro
Maxtor 20G and 256MB PC133
Pana.48x and Ricoh 7060s
Many thanks.
Patrick:confused:
jere01
289
Try formatting and starting from scratch without using a Ghost. Install the Via 4-in-1 drivers and nVidia's Detonator drivers along with Direct X 7 and if you are still having problems after this then it could be a problem with your card.
