Problem with Geforce 2
firestorm225
326
I just got a Geforce 2 and put it in my comp, and Im getting the same framerates as my old TNT2. I think the problem is that I only have a 200 watt power suply, but im not sure. If I do need a better power supply, should I take the Geforce 2 out while I wait for a new one? Am I messing it up by leaving it with the 200 watt power supply?
Chuffmaster2k
452
I don't think the power supply is your problem. The GTS's are not as power hungry as the original geforce's.
What drivers are you using?
What processor?
What motherboard?
With a little more info we can help. :)
Good Luck.
firestorm225
326
Drivers - The latest D3 (6.31)
Athlon (original Slot A) 700 MHZ
Generic gateway motherboard
128mb ram
The vid card is an Elsa Gladiac Geforce 2 GTS 32mb
firestorm225
326
Maybe its a problem because the motherboard is the AMD 750 design and that had incompatibilty problmes with Geforce cards?
