- May 12, 2002
- 17
- 0
- 0
i just got through reformatting/installing windows xp pro to try to solve my problem, with no luck... so i turn here to hopefully get some advice/suggestions.
my system specs:
asus p4p800 deluxe
p4 2.8c
1gb apacer pc-3200 ram (CL3) (2x512mb, dual channel)
ati radeon 9800 pro (128mb, using catalyst 4.7 drivers)
sound blaster audigy 2 platnium
powmax 400W power supply
nothing is overclocked, never has been...
while playing games (it has happened on pretty much every game i've tried: wolfenstein enemy territory, max payne 2, battlefield 1942) i notice a lot of different colored blinking "squares", and other blinking areas. for example, here is a screenshot of it in wolfenstein enemy territory: http://img59.exs.cx/img59/759/wolfet.jpg.
so, at first i tried patching the games, updating my video card drivers, and flashing my motherboard bios (all to no avail). i tried lowering the resolution, and graphic quality, same results.
i then proceeded to reformat my hard drive, and try with a fresh install... no dice. so, i installed the asus pc probe utility (monitors temperature, and voltage)... motherboard and cpu temp. are 35/30 degrees celsius respectively while just browsing/etc. that jumps up around 5-10 degrees while gaming... but, the voltage monitoring part of the utility is saying that my +3.3v line is at 2.96, could this be the cause?
as far as cooling goes, the case i have is a chieftec AX-01BD (http://www.directron.com/adx01bd.html) with a side window (has a fan on it)...two fans in the back, can't remember if there are any fans in the front (i'll look later)... if this is an issue of the card overheating, what could i do about that?
just for reference, i took out the 9800 pro, and put in an older card (a geforce4 mx460) and it does not have the problem. so, could this problem mean that my card is defective?
i've searched around, and tried posting on some other forums (no luck with that), so i'd appreciate any help i can get... thanks.
my system specs:
asus p4p800 deluxe
p4 2.8c
