Problem with freezing hard disk Samsung 2TB HDD
boss1983
15
Sometimes freezing no reasons ..
HD Tune Pro software malfunction appears that yellow stripe picture
[/URL][/IMG]
If the hard disk is dying? I need to buy a new hard disk?
bryanl
1,157
8
How is your SATA cable, and did you install the firmware update to correct problems with dropping queued commands? However I doubt the firmware is at fault.
boss1983
15
3 SATA cable connected to the mother, been 3 years no problems.
Started a month ago and now freezing freezing tip more. Firmware updates have been about two years ago.
bryanl
1,157
8
I was thinking of reseating the cable at both ends.
I didn't know more than one firmware update was needed for any version of the Samsung HD204UI.
coercitiv
7,391
17,531
I substitute a new cable and the same problem does not change.
Taken from another forum:
Current Pending Sector = ACTIVE VISIBLE bad sectors that CANNOT BE READ but are still visible to the operating system.
Writing to this sector will solve the problem; if there was physical damage it will be realloacted by a reserve sector and the Reallocated Sector Count raw value will increase.
So you have a few sectors that cannot be read. Use a disk utility to check and mark bad sectors. You system probably freezes when trying to read them.
[PS] if that counter increases any further, backup your data.
nk215
403
You are a lot braver than I am. I would backup data immediately and full then HD from my system. There's no way I would trust a HD when sectors going bad in use. (I am OK with bad sectors mapped out at factory).
Elixer
10,371
762
Get a new HD, and make backups of the current one if possible.
When you have the data copied over, then, you can format the old HD again, and use it as a scratch drive, until it finally dies out.
Soulkeeper
6,738
156
noticing your g-sense error rate is at 2479
have you been rough on the drive ?
boss1983
15
Because sometimes freezes. Looking for a great new hard disk. Please help me buy a 2TB hard disk HDD for games and movies, software downloads
Elixer
10,371
762
HGST or WD are good, but, remember, ALL HDs will fail, so, always make backups of important data.
HalfCrazy
853
When it comes to WD drives black, blue, green versions. They have a slight performance difference. Maybe this will help you pick which drive is best for your needs.
Black has the best performance, but are also the loudest and most power hungry.
Green has the lowest performance, but is also the quietest and least power hungry.
Blue is the sweet spot between performance and resource management.
Data-Medics
131
www.data-medics.com
In all seriousness though, the SMART data doesn't look bad. It shows some possible pending reallocated sectors, but no actual reallocated sectors.
I'd first backup the data 100% and then try running some further diagnostics and/or benchmarks on the drive. It could have slow reading sectors, which aren't bad yet, but likely will become bad very soon or even a weak read/write head.
boss1983
15
I suffer a lot about freezing games and movies ..
I need to buy a hard disk head fewer problems
Elixer
10,371
762
Bad hard drives are like bad meat. When in doubt, throw it out.
Hey, you could be on to something here...they could release an obnoxious gas when they are about to die.
Then we can have threads about 'why does my HD stink', or 'My computer smells like an outhouse'.
boss1983
15
Hey please help me recommended hard disk .. I did a full backup. Looking to buy a WD Black hard disk worth?
