Problem with dynamic disk hard drive
Azndude51
2,842
4
I reinstalled WinXP Pro after upgrading my computer. I didn't realize that one of my hard drives was a dynamic disk. Now after reinstalling windows, it can't read off that hard drive, though it is detected. It's a 300GB drive and I didn't back anything up on it (I know, that was stupid of me). I know that it's impossible to convert it back to a basic drive w/out losing the data, but is there anyway I can somehow copy the data off that drive first? Luckily I don't have anything irreplaceable on it and I backed up my REALLY important stuff, but I don't really want to lose all those files.
Jiggz
4,329
You can convert to dynamic without losing data. But not the other way around. Read this
RebateMonger
11,586
This isn't necessarily the solution to the OP's problem, but there's a non-MS-supported method to convert a Dynamic Disk to a Basic Disk without data loss. Here's the Windows 2000 method, but either it also works with XP, or there's a similar method for XP. It's been mentioned on the Anadtech Forums several times before. I suggest a web search for the XP method:
Arstechnica: Convert a dynamic disk back to a basic disk without data loss.
Azndude51
2,842
4
It seems like data recovery software might do the trick. I found this program, using the free trial I am able to view all the files on that drive. However, It costs $69.99 in order to actually save those files. Do guys know of any, cheaper, alternatives to that program?
