Problem with DVD-ROM drive not reading data
Ylurien
74
I have a DVD-rom question and it feels like I?ve looked everywhere for the answer.
I recently put together a new system with a new DVD-ROM drive (Pioneer DVR-112) and Windows XP. My problem is that the DVD-ROM in one of my computers is not able to read data from CDs or DVDs while in normal Windows XP mode. It IS able to read CERTAIN CDs or DVDs while in safe-mode, however.
I get two kinds of error messages when trying to read from the discs. I am running Japanese windows, so one of them contains some Japanese, but the other one is all in English. They are:
1. ?XXXX is not a valid Win32 application.? (Where XXXX is the name of the application)
2. ?Only part of a ReadProcessMemory or WriteProcessMemory request was completed?
The error message I get depends on the kind of disc that I try to read from. Either way, I can neither access the data on the disc nor the icon that is associated with the disc and its title in the My Computer screen.
Another couple of things to keep in mind are that I have tried turning the IDE mode for both the DVD-ROM drive and the hard drive to PIO mode only, and I have installed Windows XP to that machine with no problems reading from disc (obviously, since Windows XP is installed and running perfectly. ) So it is very unlikely that a problem exists with the drive. Flashing the BIOS for the drive would be fine and I?d try it but I don? have a floppy drive to use for the process.
So what I?m thinking is that the problem lies somewhere in how Windows XP is looking at the drive, and somehow not allowing it to read data from the disc.
Any help with this would be greatly appreciated!
dclive
5,626
Jump to my website (see my .sig) and you'll see what to do to try to troubleshoot - basically remove a few filter drivers via the registry editor.
If you have any further questions let us know.
N2gaming
374
Hi Ylurien
I'm glad you posted this as I have a Pioneer DVD-RW DVR 212D(SATA) and mine does the same freaking thing...please post your results so I can try to get mine working correctly...thanks
N2gaming
374
dclive
Is your website still up? I just rebuilt my system (mobo-died) and I still have a couple of CDs/DVDs that my SATA-DVD burner wont run, btw, I just tried your website and it seems to be down but then again I am at work right now...
or does anyone know a work around for some of these stupid SATA problems? THANKS
dclive
5,626
The ISP is experiencing technical difficulties. :)
Try again tomorrow. Bear in mind if some DVDs work and others don't it's typically a DVD issue, rather than a software issue.
