problem with dvd drive length and 7237 case
Special K
7,098
I just got a new sony dvd rom drive and I am currently using an enlight 7237 case. The problem I have is that the drive does not seem to fit correctly into the drive slot because it is shorter than my other drives. I put the mounting rails on the drive (only 1 way to put them on because there is only 1 set of screw holes to use) and after I put the drive in and put the front of the case back on, the dvd drive is about 1/2 inch back into the case from the front panel. My other drive (and the old one that the sony replaced) were lined up perfectly with the front of the case. Is there anything I can do to correct this?
Match
320
When you say there is only one set of screw holes, you mean the dvd drive right? My 7237 drive rails have multiple sets of holes in them so that you can mount different sized drives.
Special K
7,098
Ugh I can't believe I didn't notice that earlier... thanks for pointing out the obvious to me.
