I have 2 harddrives on primary and 1 cd burner on secondary. I was burning a cd the other day when i realized that the buffer moved alot. I took a look under device manager and found that only my master harddrive was on dma and the others are on pio. I tried messing around in the bios to get dma to turn on, but it won't. I took a look at the event viewer and discovered this.
The driver has detected that device \Device\Ide\IdePort0 has old or out-of-date firmware. Reduced performance may result.
Is this the firmware for my cd burner or hd? How would i fix this? BTW, ACPI is enabled in both my bios and windoze.
Thanks
Computer Specs:
Asus P3V4X
P3 750mhz
1 fuijitsu 2 gig (master)
1 maxtor 5 gig (slave)
1 Acer 10X4X32X (master)
Windows 2K
Thanks
Computer Specs:
Asus P3V4X
P3 750mhz
Windows 2K
