Problem with devices sharing IRQs and Memory Addresses..
jere01
289
I having trouble with the new computer I built (specs below). The problem I am having is that I have been getting the odd random blue screen while using my computer for normal things, ie. word processing, web browsing etc. The other problem I am having is games don't seem to work too well; I get freezing and crashing.
I took my system in to a shop to have it checked out and they couldn't find anything wrong with it, however they did check all of my hardware and verified that it was all working fine. They told me that they thought it was a driver issue but I can't seem to figure out what that means because I have always run the same software and OS on all of my systems and keep all of my drivers up to date.
I am wondering whether the problem is something to do with shared IRQs and/or shared memory addresses. I took this screenshot of my system information, and as you can see, my video card is conflicting in a number of places. Before I took this picture, I also had conflicts with my sound card but I moved it to another PCI slot and they seemed to go away. The problem is, I can't move my video card and I have no idea how to make those conflicts go away.
So my question is, could it be the fact that my video card is conflicting that is causing these problems and if so, how do I fix it?
Thanks!
bacillus
14,517
with my p4c800 the videocard also shares its irq with the usb host controller.
there is no way around it though I don't seem to have any of your troubles!
did you install the intel chipset drivers?
jere01
289
Oh really? damn... well I don't know what the problem could be then.. that was my first guess.
Yes I did install the intel drivers..
