Originally posted by: Anubis
wtf is a x50v?
Originally posted by: Gobadgrs
I had a problem like that with mine after I upgraded to the A03 rom. Heres what helped and made my system a lot snappier!
See the wireless icon in the bottom right of your screen? Tap on it. You should get a wireless menu to pop up.
Disable power save mode and uncheck the box that says disable WLAN when battery gets low.
I got that tip from Aximsite and its made my X50V a lot better 🙂
Originally posted by: RossMAN
http://www.aximsite.com/boards/forumdisplay.php?f=109
Thanks,
I will try that out. Is there any accessories you recommend for this pda? I have A GB of SD and 1GB of CF. I alrady have 2 high capacity 2200. I need a good case that can hold the fat battery. Any recommendation?
Thanks
Thanks,
Thanks
I just have the GPS. I have a 2GB CF and 1GB SD for my GPS maps. The 2GB is for my media. I have the rhinoskin case for mine b/c i don't have any big batteries. What I highly recommend is that you head over to aximsite and get fairuse and betaplayer. Fairuse lets you rip your dvds right to play on your PPC. It looks frickin sweet as hell on the PDA.
Drop me a line if you have anymore ?s
