Problem with dell U2913WM digital
mdbusa
49
Hello
Just got a dell U2913wm monitor
I have a xfx 7750 card driving 3 monitors with eyefinity
i cant get the resolution to work correctly on this new monitor--
only the dvi single link cable interface will allow native res of 2560x 1080 but then the screen is all messed up--fonts and display out of focus and not usable . if i set it to 1920 x 1080 it works but that is not the res that i want.
all of the dvid d dual connector cables only can display up to 1920 x 1080
dvi to hdmi also can only get to 1920 x1080
i installed latest catylyst etc... nothing works
i also tried as single monitor--same effect.
maybe a dvi single to vga adapter will work??
on win 8 btw
RFC Rudel
49
Hello
on win 8 btw
I have the same monitor, I use 2 GTX 480 in SLI, W 8.1
go to basic first, 1 monitor and use the DVI-d or hdmi or DP (or please give more details of your gpu ports).
you have 3 U2913wm?
Remember to install the proper monitor driver, check if the monitor is detected properly, and check your cables.
the monitor can be pushed to 85hrz.
mdbusa
49
you have 3 U2913wm?
on the advise of dell support forum I shut down and connected only the new dell with dvi-d and it works now--connected the other 2 monitors and all are working perfectly--have not yet reboot with all 3 connected.
my other 2 monitors are a lg 23" and an acer 23"
the 29" dell is nice for adding lots of daytrading charts although I could have gotten a U2713HM 27" Wide AH-IPS with LED | 2560x1440 for only $50 more
thanks for your help
