- Apr 20, 2003
- 32,236
- 53
- 91
My roommate has an RCA r52wh77 52" CRT Rear Projection HDTV that we have in the living room. Basically he bought it broken for cheap. It looks like it was dropped.
I've been messing with it for the past month trying to improve the picture. At first I only played with the service adjustments and tried to compensate for the messed up screen. I finally took it apart and fixed the screen, which had been knocked out of position which caused it to be wavy and not flush. I ended up fooling with the lens focus (both manual and digital) and the color saturation. I probably shouldn't have touched either.
Anyway, it seems like I made the original convergence problems worse. I don't know if it was something I did inside the set, or something I adjusted in the service settings but the screen's convergence changes depending on the brightness. It was always like this, but now it's a lot worse.
Here is a diagram of what is happening since this is hard to describe in words:
TV displaying a dark 4:3 image
TV displaying a bright 4:3 image
As the brightness increases, the shape of the image is no longer square. The corners of the screen are stretching. This really isn't that noticeable when watching a 16:9 image. The problem though is that I'll set the convergence and it'll look fine, but as soon as the brightness changes the colors no longer converge at the sides of the screen and it looks pretty bad.
I'm pretty sure it's an ITC222 Chassis.
Any ideas on how to fix this thing?
