Hi folks,
I have a couple questions. This is my first time building a computer, and I'm a little stuck as to where to go from here. My idling CPU temp is (according to CoreCenter) 46 deg C, and when I ran the CPU Arithmetic benchmark in Sandra 2005 (which took about 1 minute or so) the temperature went up to 53 C. Aren't these high for idling and slightly loaded?
Furthermore, when I run the CPU and BIOS info module in Sandra 2005 it stops almost immediately and says my CPU has failed. That seems "not good." It has been doing that since I changed the BIOS from the "safe" setting to the "optimized performance" setting.
I am pretty sure that I installed the (stock) heatsink correctly...or so I thought?
My other question is: how do these benchmark results look? I don't know anything about benchmarking yet, or what I should be looking for. What other benchmarks should I run or would be helpful in assessing what I should tweak on this system?
Sandra 2005 CPU Arithmetic test: Dhrystone 9146 MIPS/Whetstone 3254/4261 MFLOPS.
3DMark05 was around 3300.
My system:
AMD 64 3200+ CPU (939) with stock HSF
MSI K8N Neo2 Platinum
1 gig (2*512) Corsair Value Select RAM
BFG nVidia 6800 OC
Seagate 120 gig SATA HD
NEC 3500 DVD writer
Antec Sonata Case with stock PSU (Antec Truepower 380 watt) and cooling (1=one 120 mm case fan)
Hauppauge PVR-150
Windows XP Media Center Edition 2005
And I'm not overclocking anything that I know of (because I wouldn't know how to if I wanted to yet). If it matters, this system will be mainly for gaming and acting as a media center PC.
Thanks folks,
Jeff
My system:
BFG nVidia 6800 OC
NEC 3500 DVD writer
Hauppauge PVR-150
Thanks folks,
Jeff
