Problem with computer: it's slow, help I need to fix it.
krunchykrome
13,413
Heres the problem, my computer is acting very slow. When Im typing a sentence for example, there is a 3-4 second delay from when I hit the keys to when it appears on the screen. And it's slow when I scroll web pages. Recently, I've vistied some "questionable" PrOn sites and downloaded some vids. When I say questionable, I mean they're not the sites that I usually visit. How can I get my computer back ot the way it was before?
bradruth
13,479
Originally posted by: krunchykrome
Originally posted by: vi_edit
ad aware
Thanks buddy, but I would like to fix the problem right now....any suggestions please?
So getting rid of the spyware that's slowing your computer down isn't a good suggestion?
krunchykrome
13,413
ad aware
Oh ok. Sorry. So how would I go about doing that?
datalink7
16,765
ad aware
That might fix the problem right now... not sure what you mean? :confused:
TheBoyBlunder
5,742
Ad-aware and spybot. That's all I can reccomend.
Oh...you want an immediate fix...hmm...well, I think I can help with that.
Click on start. Click on run. Type cmd. Hit enter.
Type format C:\ in the window that pops up. Hit enter.
If it asks "are you sure", say yes.
Your computer should be much faster when you're done.
/I take no responsibility if you're actually dumb enough to do that.
datalink7
16,765
ad aware
Ad aware.
:p
Heisenberg
10,621
ad aware
AdAware. Download and run.
saxophonoia
2,835
ad aware
ad aware....it's a program EDIT: not fast enough with my response
vi edit
62,484
8,345
Downloaded adaware...running check through computer right now...thanx
Be sure to click the little update "globe" in the top right to get the latest reference file.
krunchykrome
13,413
Awesome, it worked. I downloaded and ran Adaware and spybot and I guess it "cleaned" my computer. It's back to normal.
Thanx
TechnoKid
5,575
Install spyware blaster too, it helps prevent the spyware from ever being installed. Also, if you have a problem that neither AdAware or SpyBot Search and Destroy can remove, d/l and run a program called CWShredder.
krunchykrome
13,413
What does CWshredder do?
