Problem with ceiling fan. Lights dim plus they take seconds to turn on.
Status
Not open for further replies.
cmf21
977
Ok. So over the past few days, I've been helping my sister and brother in law move into their brand new house and have helped them install 6 ceiling fans. No problems until we get to their master bedroom. We install the ceiling fan and notice that the lights take a second or two to kick on plus they appear to be dim. Fan works fine. We take down the ceiling fan and double check all of our connections. Everything appears fine. Try the light again and have the same problem.
We check out the manual but it's no help but does mention this power-limiting circuit thing where you can't use bulbs that total 190 watts or more otherwise the lights might appear dim. The fan came with 4 40watt bulbs, which is 160 watts so the bulbs shouldn't be the problem.
What's wrong? Could the power limiting circuit in the fan be bad? Could this have anything to do with the lights taking a second or two come one?
Found nothing online except talk about dimmer switches and remotes which they don't have. I'm assuming the unit is bad and will tell her to take it back to the store.
AnonymouseUser
9,943
107
Have you tried the fan lights with only 3, 2, or 1 bulb?
This has been my "I really don't know what the issue could be, but that's where I would start" thread bump.
cmf21
977
Tried removing bulbs already, still dim and takes seconds to come on, New house, nothings unpacked yet or plugged into outlets.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Tried removing bulbs already, still dim takes seconds to come on, Nothing else is plugged into circuit. New house, nothing unpacked yet.
Are you sure? I've seen a lot of bad wiring jobs that had more than one room on the same circuit.
Paperdoc
2,512
380
You could test the overloaded circuit hypothesis by temporarily wiring it in another room that is KNOWN to be on a different circuit. But what you describe seems to me very unlikely to be an overloaded circuit.Your suggestion of a faulty controller inside seems much more likely, especially since the performance is the same no matter how many bulbs are screwed in. Get a replacement.
AnonymouseUser
9,943
107
Swapping the light kit to another fan should isolate the issue. If it exhibits the same behavior on another fan it's the light kit, otherwise it's the circuit or fan.
bruceb
8,874
111
I agree, the neutral is not making good contact somewhere. Probably at the box or location where the feed cable going to the fan box is coming from.
Status
