problem with cd-writer drive
terryd
192
i'll try to make this as short as i can,i had a hp 8590c that i had gutted and started with a new msi k7t turbo-t-bird 800,new tower etc.... i kept the 27 gig,128 mem,pioneer 113, and the hp-8100 cd-writer plus. my problem is everything is working great except the
writer,when i load a cd in the drive it sits there and for the most part does nothing.i
haven't bben able to burn a cd at all. needless to say it worked in the old setup and doesn't now. i believe all three drives are on the same cable. if anyone has any ideas i
welcome your suggestions,i'll get some more info if i can.also i believe it's using 98se
drivers,thanks,terry
buck
12,273
4
Have you gone to the HP website and DL'd all the drivers and firmware there is? What kind of burning software are you using?
Generalen
709
I doubt all three drives is on the same cable becouse u only can have 2 on the same cable
try swich cable so your cd-writer is on 2:end cable whit your cd and your hardrive on the 1:st cable.
terryd
192
thanks i'll try switching cables and as far as hp the only dl's they have are updates and not any actual drivers,terry software is
nero 5.5 or easy cd
