Hey, I'm hoping someone here can give me some insight on my problem.
Before I start, here's a rundown of the system:
OS: WinXP Home SP2
CPU: AMD Athlon XP 2000+
Motherboard: ECS K7S5A
Chipset: SiS 735
BIOS: AMI
System Memory: 1024 MB DDR SDRAM
A few weeks ago I booted one of my machines and saw a message during boot that stated that there was an error with the CMOS settings and that default settings had been loaded. I noticed that the motherboard recognized my processor as an AMD at 1250 MHz, rather than the full frequency of the 2000+. So, I went to my BIOS settings and changed the front-side bus and DRAM frequency to 133 Mhz (the default is 100). This time the board recognizes the processor as an AMD Athlon XP 2000+ (as it should). However, Windows will not load. The system reaches the Windows 'loading' screen and after the screen disappears, the monitor turns black and Windows does not load. At this point I have to manually shut down the system. I have tried the Knoppix and Ubuntu live cd's and they don't load either.
If I leave the front side bus and DRAM settings at 100 MHz the system works fine, but it only recognizes my processor speed to be 1.2 GHz, which is wrong.
Before the CMOS error, this machine ran with 133 MHz settings at the full XP 2000+ rate. Can someone explain to me why the machine will not properly load the OS and how to fix it? Thanks for your help!
OS: WinXP Home SP2
Chipset: SiS 735
BIOS: AMI
