Problem with Asus P8P67 PRO and Corsair memory
kipni
OK, here i go
my setup
Intel 2600K
Asus P8P67 PRO Rev.3.0
Corsair CMX8GX3M2A1600C9
Asus ENGTX570 DCII/2DIS/1280MD5
my problem is similar, but worse
i bought the parts 8 months ago and assembled everything booted, installed windows 7 64 bit ultimate and it worked fine.
Now i get the red dram light that stays on.
I wanted to try the things you guys all proposed, but booting with only one stick of Ram is not possible (not in A1, A2, B1, B2) only thing is get then is standby led flashing green together with other leds flashing red.
So only thing that does'nt goes in the green standby flashing is the two sticks of RAM in A2 and B2 (like suggested) but this goes into red DRAM Light.
I tried the memOK several times no solutions.
I want to Clear RTC RAM but i think that isn't working for me. Always the same DRAM light, i never can go in the bios to change things like ram frequency, ...
what can i do?
So what exactly is your problem? I am still unclear at this point what you are experiencing. Also what is the vdimm that corsair ram set requires?
