I've got a problem with Antec power supplies. My work system went down a few weeks ago. For some reason, the power plug that plugs into the motherboard burned. It burned up the plug on the power supply and motherboard, so I replaced both. I had an indenticle motherboard laying around, so I installed it. I was using a (cheap) power supply that I had laying around until I could replace the power supply with a new one. It's some kind of LLC brand or something and it's only 250 watts.
This combination worked perfect btw..
Anyway.. I priced out power supplies, namely Antec, because I've had good luck with Antec power supplies. Instead of buying the 300w power supply by itself at Newegg, I figured that I'd just go ahead and buy the SLK2600AMB case instead with the power supply for $15 more than just the power supply. I can always use a nice cheap case.
The problem is that I'm on my second Antec power supply and I don't know what's up. What I'm doing is removing the power supply from the Antec case and putting it into my work system case. The first Antec power supply wouldn't power up at all. Nothing. DOA! The second power supply worked for about an hour and then when I shut down the system overnight, I noticed that it smelled funky. I thought it was just the newness burning off. I went to power up the system this morning and nothing. It must've died. I replaced it again this morning with the cheapo LLC 250w power supply and it works perfectly again.
Now.. I've been thinking about this and wondering if I'm accidentally killing these power supplies somehow. I've been using the lead for the fan control and plugging it into a fan header on the motherboard. Could I be plugging it into a bad lead? The power supply fan seems to work fine. This is the only thing that I'm doing differently than with the cheap power supply. The cheap power supply doesn't have a fan control.
The other possibility is if the Antec power supply that comes with the case doesn't like to work outside of the case. I can't imagine why this would be the case though.
Any ideas? I don't want to fry yet another Antec power supply.
TIA,
Sal
TIA,
Sal
