Problem with adding SATA drive to existing Raid 1 in winxp
Discussion in 'Memory and Storage' started by aghusker, Feb 7, 2009.
  1. aghusker
    aghusker Junior Member
    Aug 3, 2008
    18
    Can anyone help?
    I have a raid 1 using two 320 GB SATA drives, with WinXP Pro. (shows as C:/)
    I just bought a new 640 GB SATA drive that I wanted to add as a separate drive (eg, d:/), not part of existing RAID.
    Disk management in winxp sees the drive (after NVidia software initializes the disk), but no drive letter is assigned, and I have no option to format it (when I right click on drive it gives 'Change to Dynamic disc', 'properties', and 'help' options).
    Asus P5N32-e sli plus board.
  2. Loading...
    Similar Threads - Problem adding SATA Forum Date
    Samsung 850 EVO writes at 0.8 MB/s. Anyone else encounter this problem? Memory and Storage Jun 24, 2017
    problem with Sandisk 256GB usb3.1 / UASP possible? Memory and Storage Apr 28, 2017
    Upgraded to SSD. Problem with secondary Seagate hard drive. Memory and Storage Mar 30, 2017
    Oh dear has my new SSD got problems Memory and Storage Mar 6, 2017
    I am having a problem adding another hdd, why? Memory and Storage Aug 28, 2010
  3. VirtualLarry
    VirtualLarry Lifer
    Aug 25, 2001
    37,120
    1,316
    You're on an NVidia mobo, with RAID enabled? Check and see if RAID is enabled FOR THAT PORT in the BIOS.
    Edit: Just to be clear, if you don't want the drive on that port to be part of a RAID, you need to make sure that it's not enabled for RAID in the BIOS.
