Problem with A8N32-SLI
MuNiCh
My spec is Athlon64 3000+ running at 275*9 (2475MHz) 1.425V HTTx4
Corsair XMS 512MB*2 running at DDR 495 2.85V
Asus A8N32-SLI Deluxe
ATI X300
Sound Blaster Live! D.E. 5.1
WD Raptor 36GB
I used to run the com at this setting last week and everything was working fine until i switch it on yesterday. It couldnt POST so i clear CMOS. The first try it didnt work. So I did it a few time and it could POST again showing sth like "CMOS checksum error.." then everything is back to normal until today, the same thing happened again. I clear CMOS a few times but nth happen. What is the problem?..if the problem is because of the M/B then i will go get it replace. I jst bought it 3 months ago.
Probably needs RMAed. Sounds like at the very least your CMOS battery is bad. Try another if you have one.
Raise the VCore a notch up and loosen the memory timing. When you clear CMOS, take the battery out, too. I had that problem at the beginning but since then it's been very solid for 3 months.
