Problem With A8N-E
imported_Oliver
4
Hi,
First Excuse me for my english.
Configuration:
Box : Antec TX-1050B (alim Smart Power 500W)
MotherBoard : Asus A8n-e (Socket 939) Nvidia DDR400
Processor : Athlon 3500+
Graphic card : ASUS EN-7800GT 256Mo
Corsair Value twin (2x512) PC32000
Hard Disk Maxtor 160 Go SATA 7200tr/mn
Graveur DVD LG
Problem :
I have installed this configuration this week
At the first boot of windows installation (after the first phase of the windows installation) the problem begin.
The installation stop.
I reboot manually and the install begin again.
I continue to the end of the installation.
Windows run correctly. No problem.
But when i reboot from windows the system block.
I must stop the system with the buton and rerun.
the second time Windows run correctly.
and again again again the same phenomene when i reboot (regular)
When window stop he stop during the first page or just before.
I have test an other hard disk but same phenomene
I have disconnect the other card. i have test just with Motherboerd, hard disk, and memory and graphic card but same phenomene.
If someone know this problem please HelpMeeeeeeeeeeeeeee!!!!!!
Thak and Good day
Oliver :)
Unkno
1,659
bad sata cable? properly connected it to the HD? Try running memtest (doesn't require an OS).
imported_Oliver
4
No.
I have test memtest.
I have test with an other cable --> sa
I have use an other hard disk (sata) --> same problèm
I have test with an ide drive and that run correctly.
The problem come from SATA.
I think it's in the bios but where ?
KGB
3,042
Oliver,
Welcome to the Forums! :beer:
Are you loading the SATA drivers at the F6 prompt?
dball3
38
maxtor sata drives and n-force 4 sata does not work together, there is a compatibility issue and i don't think there is a fix for it yet. you can search on google for the documentation of the problem.
imported_Oliver
4
Ok
I think it's that.
I have change my sata drive with a ide drive and it's better.
thanks for your Help..
Bye Later.
