problem with a7v, asus couldn't help me :(
nwgtr
well this is my forth a7v mobo that i got
the first mobo was fine and all, until i bad flashed it, so i brought it back to the store where i bought it they fixed it for me, not sure if they replaced the bios or mobo (they told me they replaced mobo)
then i started having problems
when i held down 3 keyboard keys or more the mobo beeps
as long as i keep it held, it will beep every half a second.
plus like once a month it makes these screech noise when i boot up then goes to disk boot failure insert system disc. i tried just pressing anykey but it just repeats the message, so i hit reset my system boots up fine with no problems. this happend once every few weeks to a month. i noticed it only happened when i first boot up the system in the morning.
the next mobo i send to asus myself to get it fixed.
they fixed it and send it back, same problem
this is the 4th one, i would like to solve this problem, because when it gets worst like the other mobos i had, the pc freezes at post, at dos, and windows.
i brought the system back and forth to the computer store, then i found out the system only allows me to get to windows and not freeze for 5 min when i close the system and let it stand for 30minutes
so i dont want this to happen again with this mobo.
or i'll have to try another kind of mobo
what i'm thinking is that it might not be the mobo problem yet, but if i let it like this, it's going to get worst like the others eventually rendering it useless.
cause this forth one, i installed it myself but i copied the exact settings it used to.
this is like the third day i got it back from repair
the system runs fine after i installed it. but when i pressed more then 3 keyboard buttons, the mobo beep
which i realize the problem still exist. I just got the disk boot failure today when i first boot up in the morning.
also i turned on the virus boot detect now, cause i read something like this happened to the older 1003 bios. but this didn't fix the beeping of mobo if i press and hold down more then 3 keys
it beeps in dos, windows, anywhere
could u please tell me, what could cause this?
bad ide cable? connected something wrong?
like the speaker connector
when i got this mobo it is on bios 1010a
my older one was 1007, i formatted and everything
reason y i think it is something connected wrong cause the first mobo was fine, until i brought it to the computer store, after that all mobo has the same problem. but i'm not sure what since i only know little bit more then basic knowledge
it couldn't be my hd or anything else cause i tested them all
i'm running on winxp pro
before it was on win98se still has these problems
geforce 2mx, athlon 900mhz thunderbird
sound blaster live
384 mb ram
one and one more thing i noticed, when i'm playing games like q3, at certain times, my cursor just flicked somewheres else when i didn't even move my mouse, not sure if this is caused by heat, my temp is 49 C. idle and some hot days it is 51 C idle
i have my case opened and have a house fan blowing directly at it. i tried a7v troubleshooting forum and many others but no one seems to have this problem or know what causes it. even asus themselfs couldn't help. all they do is say send me your mobo, we'll replace it.
i had an a7v it started acting quirky after 1 1/2 years i think it was my hard drive so i baught a new hard drive for it and gave it to my nephew and used it as an excuse to build myself somthing new and hot,,,,,,,and i scored some brownie points with the family,,,,,,,,,,,,,,i am curantly rma' ing the old ibm hd
