Problem with a ATI TV Wonder PCI
BillyTech
30
Hi,
I have a problem with a Ati TV Wonder PCI. The computer is a Athlon 1.3Ghz,MB Asus A7A266, 256DDR, GeForce3 V8200, Sound Blaster Platinum 5.1, DVD Pioneer, Modem Aopen FM56-PLM, Power Supply 250w and the Ati TV Wonder PCI. The computer work correctly, all applications they are ok, but when a execute the TV's application of ATI, the computer freeze whitout error message. I try the old and news drivers and ATI's applications, the problem don t move. I change the IRQ for IRQ 3, it change anything.
If you are a idea or you saw this problem, WRITE ME PLEASE =\
Thx!!!
vailr
54
Only 250 Watt PS on an Athlon 1.3 GHz? Try an AMD approved 330 W or better PS.
BillyTech
30
I try with a Power Supply 300watts, same problem.
I change my video card for a Radeon 32DDR, same problem too.
I change my 256DDR for a other, GOD HELP ME!!! =\
jblondi
538
is your tv card next to your sound card by anychance? Probably both sound card, and tv tuner are fighting for resources from the same PCI bus. Try and move the ATI card to a different PCI slot.
BillyTech
30
I change the TV card in other slot (1 and 3), they is the same problem.
I change the SoundBlaster too, same think.
I unslot the SoundBlaster, same think too.
At this time a suppose the motherboard(with chipset ALI).
BillyTech
30
Do you have some problem with your TV's application???
Do i can install a other TV's application??
cbuchach
1,164
Maybe try running a different TV app?
Dscaler is a great TV viewing app that is freeware. You can pick up the latest version here. Make sure to get version 3.0.2. Set your tuner to Phillips NTSC (if you are in North America) and give it a try.
Slugbait
MaxPC had major problems with it, too. It's one of the few pieces of hardware to win a "2" rating. However, MaxPC had better luck with it than you're having.
Try searching over at theMURC, there might be a few people in those forums who have had the same problem.
Raspewtin
3,634
<< Do you have some problem with your TV's application??? >>
no, i was having mucho problems and had to reinstall the SAME drivers 3x (7.1) i don't know what clicked but third install worked fine. also i am running xp and it needed video update to dx 8.1 to install the video update i had to run it in win2k compat mode and the program diddn't get to install all files (crashed half way through) but apparently finished enuf files to install the dx componenents necessary for the application to work. btw system running it on is system in rig (with win xp)
I'm not sure if there are other programs.
BillyTech
30
HEY EVERY BODY!!!
I found the trouble!!! (or a other alternative)
I have testing the same system with a EPOX 8K7A(chipset AMD).
I don t reinstall windows. Just uninstall ALI drivers and install AMD drivers. And the test pass!!! The system don t freeze!!!
I m not sure at 100% but i think it s a incompatibility between ALI and the ATI TV Wonder PCI or ALI's drivers and TV card. But i m repeat i don t sure at 100% of this affirmation. And i don t have the time to install a beta driver. The costumer wait her computer. =(
I wait a E mail by ATI for this information.
Thx every body!!!
