mcveigh
OK this is a PITA.
new system with XP pro, sapphire 9700 pro w/ directX 9 and catalyst 3.0 drivers. connected via DVI cable to a dell 17in lcd monitor.
I get nothing. nada zippo zilch. If i use the dvi->vga adapter it works fine (Lcd has vga and dvi inputs) if I use the other vga port on the card it works fine.
now before I updated to 3.0 drivers. it had worked on this monitor. but it would not work with a 50in plasma screen (that's going to be it's main display when all is done) I suspect the custom dvi cable for it, so I tried it with the dell lcd and a dell factory 18 pin dvi cable. it worked.
I'm wondering now if the dvi port is shot?
tomorrow i'll try using the old drivers, but any input would be appreciated
edit:
system specs
SB51G SFF case/mobo/power supply
512MB corsair pc2700
P4 2.4B
liteon 48x24x48 cdrw
sapphire 9700 pro
80GB WDSE hard drive
XP pro w/SP1
edit:
system specs
P4 2.4B
sapphire 9700 pro
XP pro w/SP1
