I hooked everything up and double-checked the connections for the cables and slots. I hook the monitor up and power on the system. The Power led turns on (so does the floppy LED, the cable is probably inserted wrong) and the fans start spinning. A couple of seconds later, I hear the hard drive revving up and the LED on the DVDROM starts flashing (like it does when it starts reading).
However, there is no video on the monitor. The monitor is a Samsung 955DF which I purchased not more than 3-4 months ago and used about a total of 10 hours, so that rules that out.
There is no code in the LED1 (which would show any problematic codes). The bright-red LED2 lights up and stays red when I start turn the power on, but from what I gathered in the manual, it just shows the ACPI status and doesn't indicate a problem.
I'm thinking the problem is probably the video card. I was using the video card in my last system, and the mobo on that old system burned out because of some power/dust problems. From what I saw, the connector that connects the PSU and the mobo had like 4-5 slots burned out and the plastic was deformed on some of the slots, and I also some capacitors near the CPU bubbling on the top. Could this have burned out my video card also? It's a 3-4 year old Creative RivaTNT 16MB (PCI)
