- Mar 20, 2005
- 6
- 0
- 0
my motherboard recently crashed, i sent it in and got it fixed(or replaced) anyways, when i got it home i put the harddrive in and it goes to the screen about windows not being shut down properly and asked to select a way to boot, i picked them all and each time it just reboots, evertime. so i installed a new harddrive and put windows on it and it works, then i put the first harddrive in to get to the data and while it was partitioned into 4 drives windows only shows it as drive D and is 33 gig, says its healthy but when you try to get in it says it needs to be formatted............... i really dont wanna lose all my info, any ideas?
in device manager, it says the file system is Raw, when populated it says 32254 space, and in computer management, it says its 31.50 gig, healthy and online.
so its like its a brand new drive, that needs to be formatted, if that info helps
My computer ran fine before, then it just shut off and never turned on so i tried everything, then i decided to just send it back to msi, i dont know if they fixed my mobo or sent me a new one
