I'm currently using 2 sticks of 512 MB PC3200 DDR400 and bought a 3rd stick to put in my system.
When I install the 3rd stick, part way through boot up, the system shuts off.
The ram is good, as I can use it by it's self or with one other stick and my system boots up fine.
It seems that I can use any 2 of the 3 sticks of ram in any of the 3 ram slots ant the system will work.
If I try to add the third stick of ram, the system shuts down.
The motherboard is an Epox 8rda+ which is suppose to support up to 3 gigs of ram.
Any ideas or advice on what to check for would be appreciated (as well as a bump)
Thanks
Thanks
