ChickenMcTest
Hey guys,
I just bought a new zalman heat sink fan for my rig. I am running a 3800X2 on a Asus A8n-sli mobo.
I installed the fan booted my comp, everything works, but, the fan makes a very loud mechanical sound. Also, rocking or gently hitting the case makes the sound stop for about 60 seconds. (aka the soviet fix)
The fan does not look wobbly, but I am not sure what to do.
In the manual for the fan it says to turn on the PWM control mode, but the only feature I can find in my BIOS is for the AMD cool & quiet settings which seem to do nothing.
To summarize my incoherent post. Is the fan broken or is there something in the bios that will fix the loud mechanical sound?
