Problem w/ Ghost Recon...PLEASE HELP!!
Josh
Gopunk wins round 1!
Round 2:
Solve this for me and you'll get it something else...or if you do solve it...and you aren't gopunk you'll get PizzaTycoon. The text is extremely blurry and hard to read, is there a way to fix that? Also -- how do you change the controls, ive selected the control and hit enter, double-clicked and did everything, it wont let me change the controls. SOMEONE TELL ME HOW!! -- bolded is more important! fix my problem and win!!
Tell microsoft about the problem 😉
No, but it could be the graphics card, not supported or something, best bet is to contact the ones who made the game.
Or you could go out and buy a cheap geforce2mx, its worth it, been playing with my friends online with roger wilco and it totaly rocks.
<< Tell microsoft about the problem 😉
How much is a geforce2mx?
the voodoo 3 should work, look in the readme, they talk about a known issue with it, implying that it should otherwise function normally. do you have directx 8? you need to have either that or a higher version.
"go to www.voodoofiles.com and get both the latest drivers and driectx 8.1"
got it from another message board, looks like other people have the same problem as you. i've also heard that changing your display settings to 16 bit might help, but in any case, getting the drivers would be a good idea.
Anyone with a Voodoo3/4/5 card, running Windows 2000 could have problems with the demo or the full version. I have the full version and the video corruption is so bad, I can't even find the quit button. With my GF2 card, it runs just fine.
vash
<< "go to www.voodoofiles.com and get both the latest drivers and driectx 8.1"
What "latest drivers?" 😛
so uh.... who gets that copy of zoo tycoon? 😉
er pizza tycoon... i've been bugging my dad to get zoo tycoon from the ms store for me 🙂
Yes, make sure you have DirectX(the new version), and maybe re0install if that doesn't work...? It may not be designed to work under XP, either.
Oh, and when do I get my copy of PT? 😀
Ok, gopunk, pm me for your prize 🙂
Solve this for me and you'll get it something else...or if you do solve it...and you aren't gopunk you'll get PT. The text is extremely blurry and hard to read, is there a way to fix that? Also -- how do you change the controls, ive selected the control and hit enter, double-clicked and did everything, it wont let me change the controls. SOMEONE TELL ME HOW!!
Why dont you just use the default buttons, they were a bit hard to get at first but once you get used to them its the best.
<< Why dont you just use the default buttons, they were a bit hard to get at first but once you get used to them its the best. >>
I dont like em, i like to use mouse, etc to my specifications 😀
<< While we're at it, does anyone know how to remove the popping noise in the game? I'm using a SB Live! with WinXP and Win98. >>
is EAX on?
If so, try turning it off
If you're using XP, turn off Clear Fonts. Or try changing the font you're using in Windows. AvP 2 has this problem also.
For controls, you might look in the game dir for a settings file. Try changing that or seeing if it's write protected
