twinturbostang
I just built a new computer and am having problems with it. About half the time during the boot sequence, just after the DMI Pool statement and before Windows boots, I get the following error message...
A disk read error occurred
Press Ctrl-Alt-Del to restart
At first I thought it was the hard drive. But I swapped in the hard drive from my old system (which is in GOOD working order) and it gave me the same exact error. Another thing I've noticed is that the standy power LED is on ALL THE TIME. According to the user manual, this should only be on when in "standy" mode.
So I'm just trying to verify that it IS a problem with the motherboard, and not something else. What do you guys think? I first posted this to the technical support forum, but thought I might get some more responses here. Link to the original thread: http://forums.anandtech.com/messageview...atid=32&threadid=1748580&enterthread=y
Here's the full system specs...
DFI nF4 Ultra Infinity
AMD 64 X2 3800
OCZ Gold PC3200, 2x512MB (1GB total)
XFX GeForce 7800GT
Seagate 7200.9 160GB SATA
NEC DVD+/-RW
Antec P160 case
Antec SP-500 power supply
Thermaltake P0075 Venus K450 cpu cooler w/ Arctic Silver 5
(2) 120mm case fans
etc.
AMD 64 X2 3800
XFX GeForce 7800GT
NEC DVD+/-RW
Antec P160 case
(2) 120mm case fans
etc.
