Problem using XP and radeon in opengl
bigredelmo80
43
Can somebody please help me?
I have winxp and 2000, and neither will let me play counterstrike at any refresh rate higher then 60hz at any resolution. I know that xp and 2k default to 60hz, but is their something to override this setting? I know nvidiia has a fix , but ati does not yet I think. BS company. Somebody please hlep. I"m in CS withdrawl here! BAD!
moejr
128
there is a program called nvidia refresh rate fix. look for it, you will find it
Rand
11,071
<< there is a program called nvidia refresh rate fix. look for it, you will find it >>
She'he is looking for a refresh rate fix for ATi, not nVidia. For DirectX applications you can use dxdiag which comes with Windows to set the DirectX refresh rate to whatever you wish, for OpenGL I'm not sure though.
LuDaCriS66
2,057
The nvidia refresh rate fix was NOT released by nvidia so don't go praising them and badmouthing ATI.... the fix was actually released by a programmer. Besides, this is Microsoft's fault.
Try this
ATI refresh rate fix
If you're not sure whether you wanna try it or not.. read this thread.. its working for the other users.
Rage3d Forum thread
BFG10K
22,709
3,002
You can also use PowerStrip to force refresh rates on pretty much any card out there.
