Problem: Spooky Hissing sounds
Hairboy
8
Ok, im new to this forum and happy to see that anandtech HAS a forum...I didnt see it before.
Anyways, I think this is the best place to post my problem so here it is.
I have loud SSSSSSHHHHHH sounds from my speakers and the did not go away when I made my new computer. The sounds randomly every once in a while (average 1/3hrs) even when the sound is turned al the way down i dont know where the problem comes from but I know where it can come from, here's a list.
The PSU (ULTRA X-conect 500watt) and the case are the only pieces I kept from the old case I think the PSU is the most suceptible of being the problem so I listed it first. Then it could be the AC97 driver or the MSI mobo (wich is a new MSI mobo (NEO4-F) but maybe its a problem MSI has on their mobos). It could also be, but almost certanly not, the monitor.
The problem is not the speakers (it does the same with headphones).
I can live with it but if you guys cant help me il have to declare it possesed and change my UV lights from Green to Red.
Scott66
501
You might have a blown speaker or your amplifier can have a voltage leak. Since you changed your computer and the noise is still there, I suspect your speaker system. Do you have an external amplifier which the speakers are attached to. If you do attach a cd or mp3 player to the amplifier and see if the sound is still there.
Hairboy
8
I do not use an external amplifier, just onboard sound and the problem isin't with the speakers because if i change speakers it still does the same thing.
And thanks for the Welcome. n_n
Hairboy
8
Well... there is no toaster or microwave powered by my PSU if thats what you mean, there's the pc and thats all, I guess. I don think I understand your statment very well.
