Thanks in advance if you post as this is a hair ripper-outter for me. The HD went in my Toshiba 1605CDS which is OOW. I got the HD bt can't get the damn case open. The screws are all removed from the bottom, including one internal screw located in the memory slot area. Anything attached is removed, battery etc. Is there something under the keys I should know about to release the board from the upper case? I wanted to ask before venturing into it. Any diagrams or anything you could point to ont he web would be helpful.
