Problem Solved (Mods Can Lock Now)
If you're getting those errors, it sounds like you might have something missing. Make sure you have a client (ex Client for Microsoft Networks), a protocol (ex, NetBEUI or NetBIOS), and an adapter...(ex network card). I would check those and then maybe see if you have a cable problem as well....
Doh!!!
Stupid me! Added Everything but NetBEUI.
Thanks a lot. I can't believe I forgot this. So easy that I guess I just didn't think to check if I had forgotten it.
