Problem solved!! (just ignore)
Hint is in bold:
The standard kilogram is a platinum-iridium cyclinder 39.0mm in height and 39.0mm in diameter. What is the density of the material?
I'm having trouble finding the mass of the cylinder.
Thanks a lot, but now I feel like an idiot. I just overlooked that first part I guess. I don't know what I was thinking. Thanks again for the quick replies.
Actually.... this MAY be a trick question I would check the answer based on density and volume = h ¶ r^2
There was an article in the New York times today about how they need to create a new "standard kilogram" because the cylinder they used before has mysteriously lost 50 micrograms compared to other measures.
Edit: had sphere volume formula there before the new weight they are proposing as a kg is a sphere instead of a cylinder.
