Problem Solved: EVGA 9800GT 1GB problem
sk560
I'm having problem with my 9800GT 1GB in windows. It's not recognized as an nvidia card for some reason in xp. XP sees it as a 9800GT in hardware profile but under Display->Advance->Adapter.... all fields are unknown.
I can set the resolution all the way to 1900 x 1200.
It's a G92 55nm card.
Problem w/ mobo? (ECS G31T-M v1.0)
I'm suspecting the bios is the culprit. Anyone has the bios for this card?
Update: just re-installed xp... same problem.
Update: win 7 beta can't complete installation.
Update: Problem Solved. It was a bad bios. Found another bios for the same card and it's working now.
Anyone looking for a EVGA 9800GT 1GB (55nm) bios, here you go:
http://www.mvktech.net/component/option,com_joomlaboard/Itemid,/func,view/catid,13/id,56235/#56235
Yes. Installed couple times and tested w/ my 6600GT.
Device Manager is showing it as a 9800GT.
msinfo32 and dxdiag say it's using vga.sys.
