PowerEngineer
I have a XP Pro and W2K Pro connected to a router. The two share the same workgroup name, and I've set up the same user accounts on both machines. Both machines are running Norton Internet Security but I've set up the local IP range as trusted.
From the W2K Pro machine, I can see the XP Pro machine in "Computers Near Me". I can access the SharedDoc folder on the XP Pro machine. I can also print on the printer attached to the XP Pro machine.
On the XP Pro machine, I've modified the security setting for each user's "My Documents" folders so that only they can access it. For example, the only listed "Group or user names" are: Administrators (XPPRO\administrators), CREATOR OWNER, Paul (XPPRO\Paul), and SYSTEM. I have enabled sharing on each of these folders too.
I was hoping that a user on the W2K Pro machine would be able to access their "My Documents" folder on the XP Pro machine over the network, but it doesn't allow it. I'm guessing that "Paul (XPPRO\Paul)" is not seen as a match for "Paul (W2KPRO\Paul)".
Is there a way to get around this problem?
Thanks!
P.S. -- I know that these kinds of questions come up all the time, but I didn't find an answer in any of the posts I read. Sorry if this is a repost.
Thanks!
