Problem Setting "Monitor Mode" on Prism2.5 based card on 2.6.0-test4
Retro2001
767
Hi. I'm running a Gentoo linux setup, based around 2.6.0-test4-mm1 with Wireless-Tools v27 and Wireless Extention v16 on my IBM Thinkpad A30p laptop with a generic prism2.5 based miniPCI card ("Harris Semiconductor Prism 2.5 Wavelan ch (rev 1)" to be exact). Using the iwconfig mode command I can convince the card to be Managed or Ad-Hoc, but it wants nothing to do with Monitor mode, reporting:
Error for wireless request "Set Mode" (8B06) :
SET failed on device eth1 ; Invalid argument.
I've found some Orinoco patches for WE v13 that are seem to be targeted at fixing this problem, but I can't seem to find any info about problems with that card and newer wireless extentions. Any ideas? Thanks.
Peace,
will
drag
8,708
hmm... wery wery interesting...
However that seems like a pretty unusual set up. It could simply be a buggy kernel driver and that is pretty likely considuring this is a testing kernel.
Personally first thing I'd do after trying the easy stuff is to try out a kernel from 2.4 and see if the problem goes away. I'd try making a backup of the modules.conf and the other modutils(?) directory were the editable portitions of the modules config lie in Gentoo. Then compile the 2.4 kernel.
Could be hardware related, but I haven't clue. Something that specific it may be a good idea to subscribe to a couple mailing lists that have to do with that hardware and experimental drivers or what ever.
I don't know much about wireless OR pcmcia cards, but that eth1 means that it's trying to set up a second ethernet connection or whatever.
