Problem Sending E-mail with SBC/YAHOO DSL
furballi
Banned
Have SBC/YAHOO DSL. Am using the SBC/YAHOO outgoing SMTP with port 25 to send out Mochamail and Yahoo mail UK. Have the 2wire SBC modem connected to the D-Link 624 router.
If I initiate the e-mail, then the mail will go out. However, if I reply to an e-mail, then the mail will not send. Is this a configuration issue with the D-Link router or is the problem coming from the SBC side?
TIA
What if you click reply but then delete the email address and type a new one in and delete the entire body and type something else? No idea why a reply wouldn't work when sending does unless it's something in the email...
I took the easy way out. Contacted SBC and request that they unblock my port 25. Going to test it tonight and repost.
I'm pretty sure the problem is coming from the SBC port 25 filter because I have no problem if I use dialup.
Thanks for your input!
most ISPs block port 25 except to their mailservers (to help eliminate people relaying...)
I've also found that they want you to go "business class" to be able to unblock the port 🙁
