Problem running DOS application in Win-XP! Help!!
WJB05
279
After doing a Clean Install of Win-XP I loaded an old DOS application that is necessary for our office and have a problem: The application (not a game) executes, but the text is elongated and only uses approx. half of the screen. The application is in full screen mode, but it is very difficult to read the text. This application ran flawlessly under Win-98 SE. Any suggestions? Thanks.:confused:
c0rv1d43
737
What happens if you switch from full-screen to windowed mode? when you say the "text is elongated and only uses approx. half of the screen", what do you mean by that? Does it use half of the screen vertically or horizontally? Other than the screwy text display, does the program function properly? Did you try any of the earlier Windows Compatibility settings in the properties dialog for this program?
- Collin
WJB05
279
Apologies for not replying quicker to your questions regarding my probelm . . . unexpected problems on the home front. When I switch to windowed mode I cannot maximize the window to fill the screen, the window is parked in the upper left corner of the screen. By elongated and uses half of the screen, I am referring to the main menu being in the upper half of the screen and scrunched up rather than being centered on the screen. The background of the program screen is the normal blue. The program appears to operate normally, with the exception of the screwy text. I am running the program in Windows 98 compatibility mode (it worked in Win-98) with display settings of 256 colors, 640 x 480 screen resolution and disable visual themes. Thanks for any possible suggestions.
WJB05
279
Update. . . I loaded another DOS program and am having the same problem: The program only uses the upper half of the screen - the bottom half is black. Desperate for DOS!:disgust:
johnlog
632
Win XP is not suppose to use the low 640x480 VGA mode may be your problem. Try using the 800x600 mode and see if that solves your problem. When you do that make sure you set XP to use large fonts if it has that option. Why are you using only 256 colors? You should be using 16-bit colors in XP. I use 32-bit colors on my system at 1152x864 mode on a 19" monitor.
WJB05
279
johnlog, Thanks for the info. . . I am at office now and the errant DOS programs are on my home PC. I will try your suggestions this evening and report on the results.
c0rv1d43
737
WJB05,
It sounds as though these two DOS programs try to exert direct control over the display, but are fairly well-behaved insofar as programs that do that sort of thing are concerned. While you are experimenting I'd suggest trying another couple of things.
I'm not sure from what you're saying just how you are starting this program, from a shortcut or from a command prompt. You can, of course, use a shortcut and experiment with the settings on the various tabs of the Properties dialog for the shortcut. I'm curious to know whether or not the program will allow you to specify and use a different font from the Font tab on the dialog. I suspect that the screen on one or both of these programs may have at least some graphical text elements. By that I mean that the program may not be using a text font but graphical representations, and that's why the text looks so messed up. You might try just running the program from a command prompt. If you decide to do this I would suggest trying both a COMMAND prompt and a CMD prompt and testing the DOS programs from the command lines of each to see what differences you may see. (If you go to Start | Run and issue "command" you wind up with an MS-DOS prompt running in emulation which initiates AUTOEXEC.NT and CONFIG.NT. Issuing "cmd" from the same place gives you the regular WinNT command console.)
I'm still not absolutely clear on the appearance of the screens, and tiny details could be significant enough to help someone spot a useful clue. Is there a way for you to post screenshots of the programs?
- Collin
WJB05
279
Collin,
I ran the program from the Run "Open" box withe the command: C:\LABELS3\LABELS.EXE which brought the program up in a window with text that was smaller, but not as distorted. I then right-clicked on the window and (to my surprise) after checking "Full Screen" the program was fulls screen! However, when I tried to do this again, the right-click menu would not appear. How can I repeat this and can I create a batch file attached to a short-cut to make it easier to bring this program up? Thanks for your assistance and interest in this problem. Best Wishes for the Holidays.
-Barry
c0rv1d43
737
I wish I could experiment with this executable to be sure. As it is, I can't really be sure what to tell you. You could create a batch file that contains simply the command you entered in the Start | Run dialog. Then you could create a shortcut to the batch file and experiment with the properties dialog of the shortcut. Or, if you can get the appropriate information about the executable you're running you can create special versions of the config.nt and autoexec.nt files and have those run to set up the environment for the executable. In this way you can create an environment for a DOS program just as though a DOS machine had been booted to run the program. As long as the program doesn't try to do something that's prohibited by the system's various protections (It won't be allowed to take direct control of hardware, for instance.) then it should run okay.
I know this may seem pretty vague, but you can experiment with the executable and its environment without risk to the system as long as you protect the data the program works with so that experiments don't involve your only copy of the data. If you get stuck maybe I can help out.
- Collin
johnlog
632
- Collin <<<
My DOS programs run as is in Windows ME. No tweaking was necessary for the old 80s DOS word processor. Runs as well if not better than it did in my 80s dos machines. Most DOS programs will run in compatibility mode with no problems at all. Just install your DOS program after installing XP then if it does not run use the DOS/98 compaitiliby mode to set it up. :)
WJB05
279
johnlog, When you say "DOS\98 compatibility mode", to what are you referring? Can either of you explain why I cannot right click to bring up the menu with various options (sorry, I do not know what it is named) when I run the DOS programs in question. I could invoke that menu (it has several tabs) only one time - and the program ran correctly. I realize this may appear to be much about nothing, but these programs are very important to our business. Thanks!
johnlog
632
Win XP has a Win98 compatibility mode. Since most DOS programs ran well in that mode check out that compatibility mode. If you do not know how check it out in XP's Help menus. Pressing F-1 most likely will bring up a help menu. Or select Start/whatever menus you can find.
Do it coolly so know one knows what you are doing. :cool:
c0rv1d43
737
WJB05,
I believe you mentioned that you had already tried compatibility mode quite a bit earlier in the thread. Did I misunderstand? You can run a program in compatibility mode by right-clicking on the executable itself, or on the shortcut to the executable, and choosing Properties from the right-click context menu. There is a Compatibility tab on the Properties dialog from which you can choose various compatibility options. I was certain from your earlier description that you had already found this dialog. The compatibility mode that johnlog is talking about is to be found in this dialog. But he's using Windows ME as a basis for comparison, and it is quite different from Windows XP. The AUTOEXEC.NT and CONFIG.NT files for general use with DOS executables OR specific versions of them to be used with specific DOS executables I mentioned earlier are some additional tools you can use to try to help a DOS program perform properly in Windows XP. Unfortunately, I only started really using MS operating systems with the advent of Windows 2000. The only DOS application I have on my machine with which to test hypotheses is the old DOS text editor, EDIT.COM. If your particular problematic DOS program needs to have specific variables set that are not covered by the Properties dialog for the DOS window (more about that below) then you may be able to set them by using these special files.
<< I then right-clicked on the window and (to my surprise) after checking "Full Screen" the program was fulls screen! However, when I tried to do this again, the right-click menu would not appear. How can I repeat this and can I create a batch file attached to a short-cut to make it easier to bring this program up? >>
I'm having a little difficulty visualizing exactly where you are. Let me tell you what I suspect may be the case, and you can tell me whether I'm right or wrong.
When you ran the DOS executable from the Start | Run dialog it came up in a Window. In order to get to the place where you set it to be running in full screen mode you right-clicked on the title bar of the Window and chose Properties. The Properties dialog would have had something along the lines of "C:\WINDOWS\system32\ntvdm.exe" in its title bar. On the first tabbed page (Options) of that dialog you clicked on the Full Screen setting under Display Options. When you clicked on the OK button you should have been presented with an Apply Properties dialog that allowed you to choose between applying this feature to the current window only or to all future sessions of windows with the same title. If you chose the latter, then every time you run a DOS program the NT Virtual DOS Machine (ntvdm.exe) window in which the DOS program runs would come up full screen. The problem with that is that right-clicking on the title bar in the full screen mode doesn't get you a properties box because you're not running the program in a "window" any more. If this is the course of events that got you to where you are now, then all you have to do to get out of the situation is to start the program, hit the Alt-Enter key combination, and you'll see the program restored to running in the windowed mode. Right-clicking on the title bar will once again get you the properties dialog for the NT Virtual DOS Machine, and you should be able to choose Font and Layout properties for your program.
If the above is the case then you should pay particular attention to those Font and Layout properties. They could very well be all you need to adjust to get this program straightened out. The default properties for the ntvdm are, among other things, a setting for a standard 80 column DOS text display. If your program was designed to display information in some other mode than 80 column mode you could very well wind up with a distorted display -- but that would depend upon features of this executable at which I can only guess at present. But you should possibly try different combinations to see if you can come up with a better appearance and function for the program.
As you can see the use of the compatibility features and properties dialogs is complex enough that discussing it all via message thread requires a high degree of specificity on the part of the participants in the thread. If I haven't figured out your situation properly, I'm going to need for you to be much more specific than you have been in describing the exact steps you are taking and the exact appearance of the screen at each step in the process if we are to have any hope of figuring our way through this little quagmire.
One other type of information may be very helpful here. If you look at the machines upon which this program is running properly and get the contents of the AUTOEXEC.BAT and CONFIG.SYS files, as well as the contents of any batch file that is used to start the program, those contents might tell us a lot about how the system environment is being "customized" to run the program properly. So you might want to post that information.
Another tack we could take is for us to converse by private message and to arrange for you to send me a copy of the program via e-mail so that I might test it on one of my own systems to see if I can come up with anything. This may not be the optimum means of proceeding if there are many support files for this executable (which would have to be included) or if you are unable to find and send me all of the relevant system environment settings that are being customized on the machines upon which the program performs properly.
If we can get this program figured out, we can create a shortcut to the executable that will make use of all of the information we have gained about running the program under an NT-based operating system so that the program starts up looking just like you want it to when you double-click on the shortcut.
One final point would be that, unless this executable is very highly specialized and proprietary, you might very well find a substitute for it that will run without any trouble under Windows XP. If you wish to explore this possibility you should post as precise a description as possible of its capabilities in the software forum to see if someone knows of a possible Windows-compatible program that provides the same functions.
Sorry it took me so long to get back to you. Hectic days, these.
- Collin
WJB05
279
c0rv1d43,
By using your directions to right-click in the title bar, rather than the window, I was able to invoke the Properties, Font, etc. dialogues. I then selected full screen and the program appears as it normally would. Furthermore, I found this would work in both the Start\Run dialogue and a short-cut. I would like to thank you and johnlog for the great amount of time and effort you used in assisting me with this dilemma. I am confident this thread will help someone else in the AT community with similar problems. :)
c0rv1d43
737
WJB05,
I'm very glad to see that you've got it sorted out. WinXP really does seem to provide a pretty good set of tools for enabling us to keep old apps running, so long as they don't get too pushy with the hardware.
- Collin
